aussieghostrider
- Jun 21, 2006
- 251
- 3
- 0
I have been using nulon products on my car for aslong as I can remember & they are worth a go if your having problems like I have with my VN.
My car has been running bit rough and hard to start when engines hot so I thought it be the spark plugs & leads but I got ngk iridiums and good set of leads on car and I replaced couple years ago anyhow I gave the throttle body a good clean with that nulon throttle body cleaner , cleaning the IDLE AIR CONTROL VALVE (IAC) and the butterfly using an old rag which helped a little so I bought bottle of the Nulon total fuel system cleaner which was $22 at repco and put whole bottle in at petrol station then put $50 of petrol to mix it up.I had my injectors removed and properly cleaned 6 months ago and needed 2 replaced cost me $300 all up and car drove ok for a bit.Im thinking my vavles were sticking or had too much carbon deposots on them so was causing the hard to start when hot issue, this additive says it cleans everything in the engine & I guess it did
Cars running great and starts first go even when hot also my fuel economy has gone up 100km's from same style driving in same area so Im happy with the result.
Also my power steering rack leaks a drop here and there so put some power steering stop leak and it worked as well.
people think oil/fuel additives are bad but if you only use nulon products you will change your opinion of that.
btw I dont work for them lol Im just a happy customer of their products.
Ive never used any other products other than nulon as they also give you money back guarantee.
If you have used their products please add to this thread and tell me how it went for you...
