oil changed but still not full
frenzal_tom
37
Pakenham, Vic
www.myspace.com
VS2 Berlina
its half way between add and fill on dip stick after 5ltrs of oil? wot could b the reason
holden007
VRII
Subaru Liberty
Did you wait a bit till the oil went down? any leaks (would be major)? exhaust smoking blue?
ScottB_33
Go Hard or Go Home
58
Nowra
VTII Berlina Supercharged
Theres a good chance the oil galleries are so badly choked with old oil sludge that the oil has been trapped in the head on top of the rocker arms and will have to drain down to get to the sump. Using incorrect grading of oil will cause this and not enough oil changes are the most common cause.
Hytes
Townsville, North Queensland
www.myspace.com
VS Berlina S1
As a guide, my oil level sits halfway between the add and full mark after putting in 4 litres of oil and a new filter on. The hand book states this is where the oil level should sit. But yeah, your oil level should be close to or above the full mark if you're putting in a full 5 litres.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Make sure the dipstick is going all the way in and then wait about 2 seconds before pulling it out. Other thing is whether the 5 litre container actually contained 5 litres and not 4.5 or whatever. Finally, not all engines are created equal - just like hooomans.
digisol
Central QLD
Toyota Landcruiser
Different ? with a warm engine stuff all would be left inside after the sump is dumped.
Either way the opposite is apparent here fellas, if there was trapped oil in a stock engine there would be more oil left in the container, not less, there are no secret holes where oil hides.
It's likely the engine has a different sump (non std) fitted to it, 5 litres for any V6 should be too much even with a new filter.
Either way, check that the dipstick is from the correct engine, if so it can only be due to a bigger sump, which is good anyway.
Think yourself lucky, the cruiser uses close on 11 litres at a change so the only way to buy it is in 20 lit drums, cheaper anyway @ around $85 / 20 lit, while that's diesel oil I doubt the prices would be much different, get together with a mate and go halves in a drum.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
So how about the oil filter - some have one way valves fitted to stop the oil draining out so the filter is primed with oil every time you start up and some do not have this valve fitted - though that goes against my argument. Also you may find that some cheap imported filters have a minimal amount of filter paper inside the can needing more oil to fill the filter. (truth or half-truth?)
The strange thing is that the book says the VS holds 4.3 litres including the filter!
Anyway we're p*****g in the wind as 'frenzal_tom' hasn't followed up yet.
digisol
Central QLD
Toyota Landcruiser
Any measurement includes changing the filter, it is pointless putting new oil into a filthy oil filter, likely partially blocked with crap.
Either way no stock V6 uses more than 5 litres, unless it's a V8 in question here ??
