AA6
After loosening the sump to disable the balance shaft, my car leaks oil until about half way on the dipstick then stops (seemed to only do it after it got hot/engine fan came on).
I cleaned the oil off the sump, and found a couple of loose bolts so retightened etc... but it looked like it kept leaking from the sump.
Does this sound right to you guys, and is it much to worry about?
