Oil pressure gauge problems!!!
UP THE RED VS
MACKAY, QLD, AUSTRALIA
VS COMMODORE UTE
So I've installed an oil pressure gauge along with volts and water temp and they both work fine, it's just the oil pressure gauge I'm having problems with, I don't have a clue why but when I turn the aircon on the gauge drops to about 30psi and originally thought voltage drop so I rewired it but still no luck, next I tried powering straight of the battery but still happened and then I tried off of my mates cars battery and still when I turn the aircon on it drops?
I wouldn't think the aircon would drop oil pressure?
Any ideas more then welcome willing to try anything at this stage haha
Immortality
Staff member
Sth Auck, NZ
Faulty gauge?
Talk to the supplier and see what they say.
Just out of curiosity, where is the oil pressure sender fitted?
How much is the oil pressure dropping?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if its a 2 wire sender run the earth for the gauge and the earth for the sender to a bolt on the engine or earth bias will make the gauge go weird
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
so 1 wire sender earthed via the sender body
Immortality
Staff member
Sth Auck, NZ
Faulty sender possibly?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Does the oil pressure drop that much (with the A/C on), when the engine is above idle.....say for example; driving at cruise speed, or around town?
Or does it come up to normal pressure?
If this is only happening at idle, are the revs dropping below normal idle, when you turn on the A/C? (thus reducing the oil pressure).
Immortality
Staff member
Sth Auck, NZ
That doesn't sound right for a ecotec engine. Thought they ran more oil pressure than that.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
Run the gauge earth to the engine block even with a temporary length of wire out the window
