Sorry for the late reply, 217 hotOil pressure showed 217kpa - was that hot or cold, idling or at revs?
I have a similar issue on my V6 and am about to make an adapter to fit a test gauge to get actually readings before l pull anything apart.
us old buggers still work in psiSorry mate i meant 2.5-3 bars which is around 35psi give and take few psi’s
So Say All Of US !us old buggers still work in psi
As I said in reply 21, my VZ V6 was doing similar things. Yesdy I fitted a new oil pressure sensor, which seems to have fixed it. When I removed the harness plug from the sensor it was a bit oily - obviously beginning to leak.
