[SOLVED] Oil pressure "thing" in filter housing? how to remove???
Sandst4rm
South Australia
VT S1 Calais Ecotec - VP Ute 3800
Anybody know how to take apart this ball and spring valve thingo?
Thanks
shane_3800
35
places
vr commo
That appears to be a press fit.
It's a pressure relief valve, why do you need to screw around with it? low oil pressure?
Immortality
Staff member
Sth Auck, NZ
As above, it's press fit and it punches out from the back side of the extension housing.
It's a bypass valve for the oil filter, it's allows oil to bypass the filter when the pressure differential across the filter gets to great.
Sandst4rm
South Australia
Was low pres at startup before i started rebuilding the engine, I know you can change the bigger relief valve spring to ecotec to get more oil pres... wanted to check this while im in there.
shane_3800
35
places
vr commo
You don't need more pressure if you have a pressure drop, you either need more restriction, IE bearing clearance (less) or more pump flow.
Immortality
Staff member
Sth Auck, NZ
A weak oil pressure spring will show lower than normal pressures but then maybe it also had bad bearings etc?
