- Apr 15, 2006
- 22,725
- 20,776
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I've seen a video where the catalyst blew out the end of the exhaust pipes on the dyno.
Yes, we've had a supercharged VE spit the cats out of the exhaust on the dyno!I've seen a video where the catalyst blew out the end of the exhaust pipes on the dyno.
How does material from the cat travel against the exhaust flow and into a turbine?Yes, we've had a supercharged VE spit the cats out of the exhaust on the dyno!
I've discovered a few empty cats and a couple of exhausts partially blocked with broken up cat. The worst cat issue I've seen was a modified XR6 Turbo Falcon break the cat up on a track day and suck bits into the turbo destroying it.
GM has a technical service bulletins for LS3’s which goes into checking the cat converter ceramic for damage along with the cylinder bores for related scoring and intakes for related crud…The worst cat issue I've seen was a modified XR6 Turbo Falcon break the cat up on a track day and suck bits into the turbo destroying it.
I don’t know and wouldn’t have thought it could but it seems to be a thing on LS3’s according to what I’ve read from GM.How does material from the cat travel against the exhaust flow and into a turbine?
Probably on overrun at high revs with a closed throttle. I've heard of it with turbo inline 6 BMW's but the Falcon, I saw the bits of cat biscuit in the turbo housing when they disassembled it. The cat was an aftermarket 3.5" 100 cell they told me.How does material from the cat travel against the exhaust flow and into a turbine?
Backfire perhaps. Too much crackle, and Pop!Probably on overrun at high revs with a closed throttle. I've heard of it with turbo inline 6 BMW's but the Falcon, I saw the bits of cat biscuit in the turbo housing when they disassembled it. The cat was an aftermarket 3.5" 100 cell they told me.
I have about 50L of it sitting in my garage... all bought at less than $40 for 5L, some as low as $32I usually get Castrol Edge A3/B4 1/2 price when they do sales...
Thankfully both my cars use it.
2nd choice is hpr5
Yes. It's a great oil. They dont recommend it 'cause its only API SL rated instead of SN that our cars allegedly (by the manufacturer) require.Do you use it in the commodore ?
Castrol lube guide does not recommend it for LS3. I am not sure why....
