Know whats involved for the conversion, obviously motor and trans need to be changed, but tail shaft ive been told fits fine? a vb vc diff bolt straight in with discs?
what box do you plan to run?? they are all different lengths so the front half of the shaft will need to be sized....unless the new box is tthe same length as the old, a new/modified cross member.
yes a disc rear end will fit straight in! all mounting points are the same....what diff do you plan to fit??...u only have 3 choices really a 10 Bolt, BW or a 9".
youl need a new master cylinder to allow for the rear discs...and you may aswell do the booster at the same time.
youll have to make a new brake hard line from the master cylinder to the diff center...or pull one from a factory disc rear ended car
VB-VK.
ive pretty much replaced or upgraded every single part in my car over the years. so youll eventualy know what works and fits with what...everything between vb-vk is interchangeable, some parts from vl's fit and front ends from vn-vs's will fit
