Opening bonnet of V6 1996 Commodore sedan after cable has broken
Brian Mullane
74
Masterton NZ
1996 Commodore V6 Sedan
Hi team,
I am seeking advice as to how to open the bonnet after the cable has broken. The cable seems to be intact on the inside release lever so must have broken at the front end of cable.
stick3
newcastle nsw
vz sedan vs ute gsx1400
Hi team,
first thing you have posted this in the wrong section go to vr/vs and you will have more members that will see your post
Immortality
Staff member
Sth Auck, NZ
Thread moved.
Grimes
NSW
VS Commodore Series II Ute
Grab a long flat blade screwdriver, get onto your back and shimmy under the front of the car. The bonnet post has a slot for the screwdriver so you can unwind the post and release it from the bonnet. If the post lock nut is a bit tight, you’ll need an open ended spanner onto a screwdriver with a square shaft. I use the biggest screwdriver in the Stanley set. It’s about 350mm long.
vc commodore
Like the Leyland Brothers
VC, VH and VY
With the early Commodores, you can actually flick the release lever from underneath...That's the lever the cable connects to right at the big bonnet release spring
Wonder whether this model is the same?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
There is a plate under the release clip on the VS, you can't get at it. The only way is to undo the post as Grimes said.
de_overfiend
Beef is Good
Tweed Heads
VS Calias
I have done it with a long flat blade screwdriver from underneath but it is a pita to do. Need skinny arms lol
