Orange engine light comes on after idle at lights
VX SS 2002
Can anyone tell me why an orange engine symble light would come up on my dash? It only appears after a long wait at traffic lights, then go's out 1 miniute after driving off again.
Short idle periods at lights are no problem. (no light no problem)
The temperature gauge never go's above normal, oil and water levels o.k.
Also it is not idleing as smooth as it used to, is it time for new plugs?
It's done 117000k uses no oil and I get 590k out of 68 liters of 98.
I would'nt call my driving conservertive, but I dont hoon around as much as some people.
Whatda yous rekon?
nsw
falcon
mine used to do that was throtle position sensor
25 bux all good:)
minux
2017 SSV Redline
Could also be low oil pressure, try an oil change, use a decent quality oil :)
accentstencil
71
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
When the engine warning light comes on it registers a fault code on the computer. If you don't know how to read the fault codes take it to Holden and they will do it, or buy a workshop manual and you will be able to do it yourself. Or you could search the forum on how to do it, it's there somewhere, I wrote a detailed description the other day for some ingrate.
Edit/Delete Message
VT-565
QLD
VT
I think it could be your oil pressure switch. I had a similar problem once before
beeks
Banned
N.S.W
XR6 5sp MKII + DR 600S
bails
Could be hose leak
Exactly the same thing happened to my Gen3 VT, found 2 holes in one of my hoses, had it replaced and the light hasn't come on since.:dance:
VT-565
QLD
VT
Which hose? i'd be interested to know which one
