slowr8
- Jun 30, 2005
- 86
- 0
- 0
- vtII Clubsport M6
Check you don't have air in the lines..
Get a presure tester or get a mech to test it for you if you don't have access to one get nrma to do it...
it doesn't cost much to pull out the water pump either (from mem 140 from supercheap?? if it's leaking of course!!) I replace the themostat and cap every 40k....if you always do little things like a hose every 10 k they will always be new as well.....
yes halfway is correct....
if there isn't anything in it you'll know about it pretty soon....
check your oil lvl as well
it should sit at halfway without moving!
If it gets hot put the heater on this will have fluid run through the heater core (which is a little radiator behind the dash) and have a fan run over it wich will help cool it...
If it isn't going over 3/4 it sounds like a thermo.
Get yourself a book mate costs ya 40 bucks!!!!!!!!!
