Overheating
Chookz103
Western Australia
Ve ss
Hi crew my ve v8 keeps blowing of the top radiator hose and losing water it seams like the system is pressurised,I have drained and flushed the cooling system and replaced both top and bottom hose and put a new radiator cap it will only go like 10 minutes of driving I found the top plastic part on the radiator were the top hose goes onto is broken of and there is nothing to stop the hose slipping off
Your thoughts
Fu Manchu
WA.
Or a suss head gasket pressurising the cooling system?
Test the cap. Is it opening?
Compression test first. Radiator second.
greenacc
Searching for the billion
VE Berlina
How many times has the radiator neck broken off?
If you keep trying to connect the hose to that broken neck that is obviously the reason why the hose keeps popping off.
Radiators typically fail at about 200,000km. How many ks has yours done?
Fu Manchu
WA.
Edit: Bloody hell. Get a new radiator. I didn’t read the post as well as I should have.
greenacc
VE Berlina
Phew, I thought a compression test was a bit over the top for a broken old radiator ;)
