Painting the door handles
shueardm
VZ SV6
Hi guys
I have 2 cars, a VT and a VZ. Are the handles identical? I mean they look identical.
So I want to get a single door handle from a wreckers and then , one by one, spray and swap, spray and swap these over 8 times, make sense?
Using paint from aerosols will I be happy enough? These Commodore handles Vt-VZ ( especially the VZ ) seem to flake far too easy and I'd like to tidy it up.
edit : yes I forgot, two are different with key holes
dgp
VF II SSV Redline
And you have left and right versions too.
losh1971
North Tas
VE Series I SS Ute
Are the handles metal? If yes you need to bare metal and etch primer, before top coat. If the are plastic you need flexi prime.
losh1971
North Tas
VE Series I SS Ute
You will need a 2 pac aerosol. You may need a 2 pac primer as some primers arent suitable for 2 pac top coat.
dgp
VF II SSV Redline
Keep looking through the pages at Holmart, they also have painted ones.
