Panhard rod bush replacement
zx7rtas
VS 5SPD WAGON
The threaded rod or pin that is fixed to the diff that the panhard rod bolts up to on my VS wagon is on a angle,pointing toward the drivers side of the car,is this normal or is it bent? Doesn’t seem right to me.The car has lowered springs ,probably 1 step down from standard.It sits about 30mm lower on one side.Maybe I should be running an adjustable Panhard Rod?
shane_3800
35
places
vr commo
It is bent.
You need to take it to a proper mechanic, to have a new one machined and welded on.
Please list where you're located so maybe you can get a recommendation.
stick3
newcastle nsw
vz sedan vs ute gsx1400
get adjustable one from ebay like i did for around hundred bucks or if you want a known brand which are more expensive
zx7rtas
VS 5SPD WAGON
It is bent.
Would this explain why it sits lower on one side? Would it have been caused by running lowered springs with a factory panhard rod?
shane_3800
35
places
vr commo
Not likely, unless the panhard rod is really tight on the diff.
The spring controls ride hight.
