The factory pistons in the ln3s take a great deal of boost we are at 23psi no issues over 350kw at the tyres
Thank you. That's pretty stout and I can only dream of that. My fwd transaxle would likely scatter in many pieces and I was told a couple decades ago the LN3 would spit the crank out at about 500 crank hp. I truly appreciate all the insight. In this case, this was a very low mile engine, 5500mi, that was stored poorly. Water got in through the missing pcv opening and built up in a couple cylinders where the intake valves were open. The crankcase, valley and heads are clean as can be, but the intake ports, intake valves and a couple cylinders rusted. #1 cylinder in particular has a fairly large spot on the minor thrust side that I am in the process of determining if it can be saved. Since it will need new pistons for sure, I was revisiting my options, when I found the Holden piston. The unique bowl shape caused me to question what the purpose is? The compression ratio is sort of middle of the road, 8.6:1, if the bowl volume I received from Silvolite is accurate, 34.7cc., or about 8.82:1 if I have the deck cut a bit to close up the squish distance to the head to about .035". If I understood your nomenclature, this piston is for what you call an Ecotec, similar to our short 8.5" deck Buick 3800 Series II, but quite apparently, not the same.
