Nut Kracker
Donating Member
- Oct 18, 2012
- 4,760
- 150
- 63
- Age
- 64
- Location
- Echuca Vic.
- VT SS 304ci (195i)
It can be very hard to determine where an A/C leak is coming from. That's why when checking for leaks, they put a dye in the system.
That allows the technician to see where the leak is coming from.
What year and model is you car? I thought it might have an automatic belt tensioner. Has it got only one belt, or one for each component?
If not the deflection should be around say.....6 to 10 mm. You should be safe with that.
The deflection is when you check the belt tension by pushing firmly on the belt with your thumb at a distance half way between the pulleys
and note how far the belt can be pushed (deflected). Measure this deflection with a ruler.
