Fu Manchu
- Mar 18, 2006
- 18,834
- 24,156
- 113
- Location
- WA.
- VZ Crewman, VZ Cross 8, & ya mum.
When the VE experiences low voltage the ECM will begin to ration voltage to a prioritised list of systems. The first to be shut down is often the stability control. It’s voltage is then used in more critical systems.
This is one of the most posted questions we see with VE’s.
Step 1. Get the voltage tested.
This will be the best $55 you spend on a while on the car.
It will do all battery checks required.
It will test charge from the alternator.
It will load test the battery.
It will work with the battery in and out of the car.
Topdon is a well regarded brand in automotive diagnostics and this device will allow you to answer a lot of questions about the battery and charge circuit health in your car.
So many will just go to their local garage and get ripped off more than these devices cost.
Hope this helps someone.
