Stability control fault & ESP off
cahpinter
NSW
Commodore Wagon 2010 V6
You might very well find a high end bidirectional scan tool finds something.
I am using another OBD tool, and the result is the same: no fault codes. Maybe need more advanced tools?
cahpinter
NSW
Now once those are confirmed good, not guessed or assumed, but with absolute solid evidence of all those things, you would move forward to checking earth points throughout the harness are clean, free of surface corrosion and torqued up nicely.
Then once confirmed after physically cleaning them and torquing them nice and snug, you move to the next thing. The ABS sub harnesses.
Of note: The VE ECM will ration voltage to systems deemed less of a priority that keeping the engine running. One of the first to be knocked out is the ABS and traction systems. The car log a fault code as a result. This does not directly indicate a fault there. The previous steps should be explored before moving forward.
Imaging hearing an engine noise and jumping to the conclusion the engine needs replacing only to discover the noise is still there and there was a loose bolt on the wiper motor.
Do the cheap basic easy stuff first to confirm they are known good. Then move on.
Thank you so much for this advice.
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
Hi @Fu Manchu , sorry I haven't bought the battery check tool yet, but I tried to use engineering mode of the commodore to check the battery. As seen in the screenshot, the battery voltage is 11.7 V and the battery charge is 69.8% (these results are after a long time of idle). I checked on the internet, and the normal battery seems to be 12.6 to 14.4 volts. So, it seems my battery is weak? What do you think?
That’s not ideal.
