power steering leak-tie rod rh
kira91
33
central coast nsw
2002 holden vx series 2
hi all
i recently discovered i was using a lot of the power steering fuild in my 02 vx
then it started to smoke
i have changed the pump however its still leaking apon looking under the car there is a build up of fluid in the rh boot with a crack on top so i assumed the splash from the boot is hitting the exhaust manifold creating the smoke
i have thought about replacing the tie rods and ends not sure if this will help,?
i am trying to get out of replacing the whole rack
whats the cheapest diy fix (i have 2 mths left of rego is it best to try and fix or sell the car )
i think its the oring in the rack what are the chances of mechanics just replacing it and/or is it possible for it to be the tie rod
yes i get that i sound dum but i am trying to get a bit more mechanical understanding of these repairs
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Replacing the tie rod end won't fix it, the seal in the rack is the culprit. A reconditioned rack would be your best bet.
Immortality
Staff member
Sth Auck, NZ
Yup. The teflon seal in the rack is kaput and it's not really an easy fix for the average home mechanic.
