power window wiring help
buster1192
vr berlina
i currently have a vr belina with factory standard power windows but i have been having issues with them as of late they lose power a minute or 2 after unlocking my car is there any way i can rewire them so they dont run off the bcm and how do i do it a bit of detail may be required im a bit newish to the wiring in it
keygen
VZ Ute & VZ SV6 Sedan
to post details , i reckon , would be too long & involved etc .
try a gregories manual for the wiring diagrams & go from there .
or another bcm & or keyhead ? brandnew straight from the wreckers . lol .
i've read that here somewhere , brandnew , from the wrecker . nothing wrong with that :)
just sounds funny .
trivia : i've not long fitted a passenger side power window & a cat 793 pwr window switch to control it :) , next , the drivers side & a pwr mirror switch to control them all - bench seat series 1 :)
not much independant down control but i'll have UP control !
Chirpstr
A new project attack
VR Berlina M5, VP M5
Sounds like the battery/alternator. Do they go faster with the car running if so, then it's prob ur battery. Try whacking some grease in the rails that the windows sit in and see how you go from there. I know mine act a little slower with the motor switched off but that's normal... If they are really slow then sounds like your battery.
buster1192
vr berlina
its not a issues with the up and down its a issue with no power to make em work
ephect
Donating Member
VS Acclaim V6
this is a factory thing, once the car is unlocked the pwr windows along with the interior light are turned on for 30sec. the real only way to do it is to get a electronic kit that either a. u can adjust the delay, or b. only set it for a longer time frame. Hook it to where it gets power feed from the bcm and buy pass it. doing this you may also disable your auto-down feature
