B
bad_boyz
Guest
Hi,
As most of you would know, I recently bought a vl calais, and sadly it seems I am experiencing some minor problems with the auto transmission.
The other night I gave it some and then for some reason I think it got stuck in overdrive, cos when I pressed the power button the power light wouldn't come on. So anyway, I pulled up in the driveway, turned the car back on, and it seemed the power button/light was working again. HOWEVER! as of late the car seems to be running rather sluggishly, cos when I put my foot to the floor, in power mode, from a standing start, it hits about 2500 revs and doesn't take off like a VL should. Also, it seems when just driving normally, the car isn't as responsive as when I first got it.
So anyway, I was driving tonight and trying to take the car up to high speeds i.e. 100km/ph +, but unfortuantly when I turned the power button off (i.e. put it into overdrive yes?) nothing happened. I tried this a number of times, but no matter what clicking the power button on or off, nothing happened. In the past it has worked cos when I've been doing high speeds and turn the power button off I could hear and feel the transmission go up a gear. Now I'm thinking this might have happened cos when I first got the car I kept fu.cking with the power button, trying to figure out what it did. So I'm thinking I might have wrecked it that way, yes?
So I was wondering, if some knowledgable person out there could help me understand what is happening to my lovely Calais, and ultimately, how to get the problem rectified?
Also, what is the standard procedure by which you check the transmission fluid level in the VL?
Help much appreciated.
Cheers,
Adz
Cheers,
Adz
