Brett_jjj
- Oct 16, 2009
- 6,805
- 109
- 48
- Location
- Tamworth NSW
- vs commodore
When testing these carbon core type plug leads, you need to move the lead around as you measure the resistance, and if the resistance readings change excessively whilst the lead is being moved around, the lead is stuffed.A lot of people just lay them out on a table or whatever and measure them without moving them around.
Ive found over the last few years that plug leads these days, even the more expensive 8,9 or 10mm ones, start to loose their "edge" after around 12 months or so. Its probably because of the higher voltages these EFI systems run at. This starts to effect how the car starts and runs, it also starts to effect the fuel economy. If you want to keep your car running at its absolute best, then its best to replace the plug leads every 12 months or so with standard replacement leads. Dont bother with the more expensive leads as the ones Ive tried, like top gun and eagle, just go the same way as the standard leads, in around the same time period.
