maddog
Mantis Motorsports
Not a huge amount of this project relates to Holden Commodores, but the powerplant will be, so I'll create a thread here about it.
I'm building a tube chassis 4WD buggy for competition. One of the most important decisions on how to build the buggy is what engine to use, and where to place it.
As such, I ended up deciding that a V6 3.8L motor out of a Commodore VS/VT would be the go. Why?
It's a nice short motor, will be easy to fit into where I'm going to put it
Easily supercharged with the factory pump (6PSi from memory) to give it a bit more get up and go
Light compared to some of the other motors I was considering
Easily available, and easy to get parts for
I'm left with some questions which you guys might be able to answer:
- Are the VS and VT motors the same?
- Where's the best place around Sydney to get either an engine with computer/wiring harness etc or a front cut? I'd also consider getting one from QLD or VIC if it was cheap enough. I have a car trailer for my competition Jeep.
- What would I expect to pay for a front cut of a VS or VT?
- There's hardly any room to run an exhaust. Basically the extractors will just taper off to open air and run that way. Any forseeable problems?
- Is there anything else I should consider?
