andyman
The Only 6sp VZ Wagon
- Mar 29, 2005
- 3,783
- 68
- 48
- Age
- 34
- Location
- Orange, NSW
- 2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
......Trailer:hmmm:
well now that ive pretty well finished my car off,:rofl2: time to move onto this, i bought it months ago but been busy, now its, its turn,
so the plan is, its going to be show trailer, in the end its going to be colour coded ssv wheels etc,
practical side, there will be a checkerplate box on the front to balance it, inside will be a generator, battery running off the alternator in the car through a dual battery isolator, this will be a setup for power to use when camping etc or if im using the trailer for work,
so specs so far,
-75x50x3 box frame with 2 cross rails
-VT front brakes (mainly for looks to fill out wheels)
-SSV wheels
-sprayed in Barbados Blue
-Deep cycle battery
-240/415V generator
-Front part of tray filled out with a steel panel
-Tub Liner
-Hard Cover
-Sealed bearing axle using vt non abs hubs
-4x4 Hilux leaf spring (nice and long will reducing harsh bouncing)
Today, got the main rails lined up and couple pilot holes drilled,
need to makes up a couple of spacers and brackets to mount those properly, then get cross supports measured out tacked in, weld it up, get guys from work to get the drawbar lined up and welded up....
anyway pics
had to cut some brackets to get rails level
so specs so far,
-SSV wheels
-Deep cycle battery
-240/415V generator
-Tub Liner
-Hard Cover
anyway pics
