Where would you cut the hole though. I looked at mine tonight and if I cut a hole in the centre it would mean removing some of the bracing. I thought about getting low forward facing bonnet scoop, much like the ones you see on Hilux utes. I'd like to get some increased airflow over the inlet manifold to try and get the MAT down even more than I already have.That looks a lot better than the factory item.
I'm of two minds about mine as I'm about to cut a big hole in the bonnet....
Where the air cleaner comes through the bonnet because of hi rise manifoldWhere would you cut the hole though. I looked at mine tonight and if I cut a hole in the centre it would mean removing some of the bracing. I thought about getting low forward facing bonnet scoop, much like the ones you see on Hilux utes. I'd like to get some increased airflow over the inlet manifold to try and get the MAT down even more than I already have.
Do you know who owns the gold Stato next to yours in this pic, pretty sure it's my old car. Got different rims now to when I owned it
yeah ok but does that mean welding in new reininforcing? Serious question BTW?Where the air cleaner comes through the bonnet because of hi rise manifold
Some fill in the gaps between the factory reinforcing and the bonnet skin. Looks awesome but time consuming.yeah ok but does that mean welding in new reininforcing? Serious question BTW?
