red_rocket05
- Jan 24, 2011
- 22
- 1
- 0
- Location
- Kings Langley
- 05 VZ SS COMMODORE UTE
Name:
Red Rocket
Model:
'05 VZ SS Ute
Colour:
Red
Engine Type:
LS1 5.7Lt V8
Gearbox:
T56 Manual
Power:
300rwkw 769nm torque
Mods:
• Twin 2.5inch catback (Redback), 4 into 1 long extractors (CHE), Twin 100cpi cats
• Pedders Extreme XA coilover suspension
• Whiteline 18mm adjustable rear swaybar
• AP Racing Front Calipers (4piston), Front DBA 5000 slotted rotors, Ferodo Performance front pads
• Textralia clutch
• Custom 30mm Front sway bar
• Heavy duty Whiteline front link pins
• Sam's performance Head and cam package 224/230
• Duspeed OTR
• Aeromotive Fuel Rails and lines
• Powerbond 25% Underdrive Pulley Kit
• 3.9 Diff gears
• HSV Rear brake set up- 315mm rotors single piston red pbr calipers with pbr pads
• Nolathane Engine mounts
• Koya Driftek 18" wheels with Kumho ku36 semi slicks
• Adjustable Nolathane castor bushes
• Sparco Hood Pins
• Aeroflow Oil Cooler
• Elite Engineering Catch can
• Ripshifter Race Version
• Cobra Monaco Pro Seat
• RPM Side Mounts mounted on original rail (can be adjusted back and forth and up n down just like normal)
• RPM 4 Point 3 inch Harness
• Removed unnecessary plastic trims, speakers and carpet except dash and centre console (also cut door trim in half and removed bottom piece for shits n giggles)
• Painted fuse boxes, coolant & windscreen washer lids, brake rotor hats, strut brace
• Removed anti vibration glue in cab and painted interior red
• Installed fire extinguisher in passenger footwell
FUTURE MODS
• Brake ducts
• Oil pressure gauge, temp gauge and shift light
• Camber kit
• Rear crossmember and rear suspension bushes
• Change all oils to Martini
• Remove exhaust after extractors and have just twin pipes coming out behind the passenger door
• Upgrade rear brake set up
• Upgrade clutch as old one is knackered
• Reduce weight in front end and add a little to the rear to stop it sliding out of corners
• Tune for better speed down Eastern Creek straight
Red Rocket
Model:
'05 VZ SS Ute
Colour:
Red
Engine Type:
LS1 5.7Lt V8
Gearbox:
T56 Manual
Power:
Mods:
• Textralia clutch
• Duspeed OTR
• 3.9 Diff gears
• Sparco Hood Pins
FUTURE MODS
• Brake ducts
• Camber kit
