Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
xtreme_sony
MY VP IS NOW A MANUAL
Vp Series 2, 3.8L Executive
I am in the process of converting my 93 VP Series II v6 into a manual. I have just started and ijust put the new pedal box in, all went in smooth. now the brake pedal is stiff. It all worked perfectly fine before. The pedal is in great condition, so thats not the prob. The brake booster itself worked perfectly fine before the pedal box swap, the brakes were fine aswell, they still work but only about 3/4 of an inch of pedal travel. Im really looking forward to finishing the conversion so i dont really want this hick-up to slow me down :) . If anyone can please help me out, it would be greatly appreciated.
Morton
For external use only
33
Fairstar the Funship
Have you turned the car on? The pedal will be stiff 'till you get the booster running on vacuum again.
xtreme_sony
Yer, Its stiff with car on and off
Yer i turned the car on, still stiff. Its like its not getting vaccuum into it, but it was all working fine before. So if you have any other great idea's i would appreciate it. Thank You. :wax:
Morton
33
Is it possible you knocked out the vac hose during the conversion?
xtreme_sony
Vaccuum hose is still connected
No the vaccuum hose is still on the booster, its all connected properly. Its like the booster has locked pressure inside it, making the pedal hard all the time, engine on and off. Is there anyway of something like this happening ?.
xtreme_sony
Yer I might just Re-Bleed them
If it was me i'd check all the hoses and lines and then bleed the brakes.
I checked all the lines and there sweet as, so i'm just gonna give the brakes a Re-Bleed and go from there. But if anyone else has any ideas dont be afraid to put them up, every bit helps. Thanks.
xtreme_sony
Its All good dont worry
Its all good just put a Booster in from the Wreckers and shes all sweet
