greenacc
Searching for the billion
- Jul 13, 2008
- 6,899
- 3,071
- 113
- Location
- Sydney
- VE Berlina
I don't believe that. If you bleed the system using the bleed screw/ or tube for a VE when there is full pressure in the system that pressure will be a lot higher than you will create with a filling reservoir. That's how I've been doing it the last 10 years and my system is always full and works perfectly.The air bleed won’t remove the air though. It removes a tiny bit and leaves a large volume in there. The only way to remove the air so the system is working properly is to either vacuum fill or to bleed using a reservoir.
The system will continue to self bleed small/tiny amounts of air through the coolant bottle.
