nzv8farmer
Hey
I have purchased a new head unit to go into our VZ wagon, i have been looking through forum to try answer a couple of my questions but haven't found the exact answer I'm wanting so thought id post instead. I've got to wait for Fascia kit to turn up so cant install yet anyhow.
1; Steering wheel direct connect, I have read in the manual that the head unit has the ability to self program steering wheel functions without the use of a module which if it is possible would be great as the kits sell for $60-$100+ so i know that the wire have to soldered into a 3.5mm stereo plug which is easy enough but i am not sure which wires need to go in which order, has anyone done this?
2; Wiring power reverse camera and head unit input, the head unit included a reverse camera which the power is sourced from the RCA plug end at the back of the head unit, which suits me fine as the head unit need the same input to switch screen over, i have found a few posts talking about a green wire behind the drivers kick panel, this sounds like the ideal wire to use, i will be running it through a relay to reduce load on wire, also introduces a fuse specifically for the camera/screen. my question about this, does anyone have a photo of this green wire, and its location or know how to easily identify it, wouldn't be the first time there are more than 1 wire of the same colour in a vague vicinity.
Cheers James
Cheers James
