RACV Comprehensive Inspection : Opinions?
Drakul
VE V Calais
Hey guys I'm looking at purchasing a 2005 VZ Calais through a private seller. It's only done 36,000km which is excellent for the year but it is still a lot of money to be exchanging through a private sale and so I'm going to do an RACV Comprehensive Inspection on the car before i go ahead with it.
It's $280 for non-members and gives the following description:
"Comprehensive vehicle inspections
A comprehensive vehicle inspection is the most complete survey of your vehicle that RACV offers. It checks even more components of the vehicle than a pre-purchase inspection.
Inspections can be done at one of our vehicle inspection centres or onsite at a private address. If the inspection is at a private address, there must be off-street parking available on a solid, flat surface (for OH&S reasons, a solid, flat surface must be available).
In workshops, the vehicle is placed on a hoist (where possible) so our inspectors have increased accessibility and visibility of components and the undercarriage.
The wheels are removed to allow access to check the braking components and the lining size and disc thickness are measured against industry standards.
If your vehicle is inspected at an inspection centre the vehicle's emissions are checked, which assists in evaluating the efficiency of the engine operation. The inspection is based on a visual external examination of components only. Components are not dismantled to examine internal parts. Some vehicle faults can be diagnosed only by dismantling the engine or are intermittent in operation and not evident from an external examination at the time of inspection.
RACV provides a 30-day mechanical guarantee on pre-purchase and comprehensive vehicle inspections, available exclusively to RACV members. RACV will provide a reimbursement on the cost of repairing a mechanical fault not identified on the inspection report, giving added assurance when purchasing a used vehicle."
I've never had such a test done on a car before and am just cruising for opinions as to whether it's worth the money and past experiences of using the service.
Cheers in advance.
AUSFITTER
40
Brisvegas
2003 VY SS series 2
I dont know what others are gonna think about it, but atleast it gives you a little bit more piece of mind knowing that the car would be fully checked over. Atleast then if there is something wrong, the current owners can get it fixed, or it is a negotiation point for the sale. Thats my thoughts anyway.
Drakul
VE V Calais
Yeah that's what i'm thinking as well, I just hope they check the car as thoroughly as the description make sound.
Also i'm just going to leave a deposit subject to positive RACV comprehensive inspection, and the seller should have no problem agreeing unless they have something to hide really.
minux
2017 SSV Redline
Have used them a few times in the past and will use them in the future.
Drakul
VE V Calais
Can the RACV Comprehensive test find out if the odometer has been wound back???
the_trademarc
The Cult Of Personality
35
SE Melbourne, VIC
twitter.com
E-Series 1 Clubsport R8
Ahhhh the RACV. Right down my ally, hehe :rofl2:
From a personal perspective, no car should be bought privately without a Comprehensive Inspection being done. It's is effectively the equivalent of getting a service done for 200 bucks, and on the three cars I've had to buy, I've done em on each of them, and it reveals so much about the current condition, how it is has been maintained, and what you can expect from it in the future.
From an employee perspective, I can gurantee you it is the best money you will spend on a vehicle, and it is one of the more highly regarded products we have.
As for the odometer, really depends on what sort of vehicle it is, if it is electronic odometer, then sometimes not (it didnt pick up the Laguna I had inspected was wound back), but I know it has picked up a VS Commodore.
And, of course, the more products you buy, the bigger our annual bonuses are :rofl2::lock::beer chug:
BT91WA
VY Calais
Definately, make sure you get a compression test done on the engine, incase there are some issues with the pistons.
My rac test came back with perfect results apart from an interior light which didnt work so it gave me that confidence to go through with the deal.
And generally cars bought from a dealer will do well in a test.
kieran.87
I'd get it done if I were you mate. Ive used them in the past, one was good, just sealed the deal pretty much and gave me piece of mind. The other time I used it as a bargaining point and they droped the price, either way it's saved me time or money on both accounts.
alien
Tullamarine, Vic
03 VY Supercharged 3.8L
Definatly go for it, my first car had the check done (i was a member though so it was cheaper). Also knew an RACV mechanic who rang up the guy checking it to go extra thorough (was a bit of o****ill and almost got the RACV guy kicked off the car lot). But even with a normal inspection they're great. Plus if they miss something it's covered :)
The report will tell you a definate no, needs a bit of work or good to go from a quick glance too. With detailed info provided to you. If your doing it with private make sure you get the original and if there's anything wrong with it take a copy to the seller.
Grouse-mouse
Donating Member
where else
ss
yeah,the owner had it done prior to sale,there was a few days left on it,he had it roadworthied after the racv inspection,it sealed the deal for me also.
