SirNemesis
- Sep 2, 2006
- 462
- 3
- 18
- Location
- Geelong, VIC
- WHII Statesman
its the air intake temp sensor getting heat soak from the extracters. happened to my ss, ran for months and once the weather warmed up the same prob happened. my car was also tuned which exageratted the prob as it was running 22* advance. fitted up an otr and relocated the iat sensor and the prob never appeared again.
took a fair while loggin it on vcm suite to get it to show up as the day i took it to my tuner was cold n overcast. it was pulling all the timing in one hit. would only happen if the car was sitting in the hot sun for a while or the car was idleing for over 30 seconds. once up to speed the natural airflow cools the sensor and all is good in the world. so id say get an otr and tune and relocate the sensor.
if you want to test my theory pull the sensor housing out of the intake duct and run it ove the radiator cover to the hole in the corner behind the left headlight and pop it into one foe the slots and run around for a few days. just make sure you block off the hole in the intake. when i did this it still had the problem but very rearly which to me indicated that heatsoak was the prob.
This is a pretty common issue with poorly tuned MAFless cars, but wouldn't be an issue with a standard tuned MAF car. The IAT is designed to correct fueling / pull spark as temperature rises, this is its purpose.
