rb25det and rb30 blocks
lil_oneblue
HZ Sandman Ute, HZ GTS, VT Senator
does the rb25det have the turbo oil lines taped into the same spot as needed to be into a series 1 rb30 block? eg can you just go by the rb25det block to work out where to drill n tap into a series 1 rb30 block? are they in the same spot?
cheers
jason
lil_oneblue
bump.........
cohn
VN28CN
Penrith
VN Calais Turbo
they are the same block, but the drillings should already be there.
on the exhaust side of the block, there will be plugs or bolts which are covering tapped holes for oil and cooling like to go on, the only thing is some blocks have the tapped holes but they don't go all the way through so all you gotta do is drill then through to the galleries.
lil_oneblue
so the series 1 blocks do have the plugs??? i didnt think they did? i thought only the series 2 blocks had the plugs and that the series 1 didnt have any?
ive got a 86 model vl that im about to wreck so ill have to have a squiz to see if its got the plugs.
cheers!
