jeepster
Over the years, I have been replacing rear brake pads, then replace all, then replace rears, then replace all.
So rears wear out roughly twice as much. First thought is that the load proportioning valve is out of whack, so too much force is going to rear calipers. But if that were so, I would expect the rear brakes to lockup anytime I did a panic stop (doesn't have ABS). They don't lockup. I am not carrying a load, there is just a towbar and tub liner that would be lowering the rear a little. Another possibility: stuck caliper slides, but they are okay.
