detox_nath83
Another VL Driver
- Aug 6, 2005
- 2,160
- 6
- 0
- Age
- 40
- Location
- Queensland(Sunny Coast)
- VL Turbo Commo
Gday Lads...
slight problem with my rear demister.
Im not getting power to the demister coil after putting a multimeter on one of the wires presuming one is the earth and the other is the supply not sure on Volts 12V maybe.???? yes i have tried both with a good earth im not getting any power
When i press the button on my control on the dash the red light turns on and i hear a relay clicking over. All fuses are good, i cant find which one it is using.. Possibly it is sharing a fuse?? either the wire has been cut/disconnected under side trims... this causing it to blow a fuse i would guess if it earths out to body.( but all fuses are good as stated above) possibly it could be in the switch itself as in light is switching on but not switching over the circuit.???(unless it runs on same as the light)..
So hopefully you fellas have got some suggestions, if i cant find it i will simply rewire in another switch to control it instead.
Thanks guys in advance.
Nath
Nath
