Update: been a while since I have been to update.
But since have sorted me a new cam, have installed it and will resump and gasket everything up tommorrow.
But since the intake has been taken off it I took the time to port match it to the ported heads.
Quite a lot had to be taken off. Black lines show the scribing marks
So after 3 hours of porting out with tge air die grinder we had this result!
![uploadfromtaptalk1381043674943.jpg uploadfromtaptalk1381043674943.jpg](https://forums.justcommodores.com.au/data/attachments/101/101453-42f209152d05e4cdff217cf4a2ad8b70.jpg)
And with all ports finished
![uploadfromtaptalk1381043715555.jpg uploadfromtaptalk1381043715555.jpg](https://forums.justcommodores.com.au/data/attachments/101/101454-b986db6dead49b94ec06089ce4fab696.jpg)
Also took a moment to enlarge the flange that the original 65mm throttle body bolted to to port match to the new bored out 70mm
![uploadfromtaptalk1381043832267.jpg uploadfromtaptalk1381043832267.jpg](https://forums.justcommodores.com.au/data/attachments/101/101455-68c62ef63388dc2f7d993b65736920db.jpg)
So been a busy day today but needed to be done.
Should hopefully flow a bit better now as the ports are no longer 4-5mm out from the heads.
Sent from my LT18i using Tapatalk 2
