Removing harmonic balancer.
fonzo
vs berlina s2
Tried a 1/2 inch rattle gun. on a 100l 5hp air compressor....FAIL. Tried to use a breaker bar Fail. bend my sidchrome breaker bar when i cranked the engine. its that tight....any ideas?
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
you'd be outta luck if those two dont work, i have heard of people using an oxy to heat up the bolt a little then give it a whirl.
nstone63
wants a new car
Roxby Downs SA
1988 VN Executive
I had to keep going with mine by using the breaker bar and cranking the engine.. maybe just keep alternating those two methods? try and gradually work it loose
fonzo
vs berlina s2
Ok so its deffently a bastard of a thing to remove. and i havnt got something outta the ordanary
fonzo
vs berlina s2
if i heat that bolt am i gunna wreck ****?
The1
QLD
www.eyeit.org
VS V6 Berlina Auto
i havn't done it myself, but im guessing the idea of it was to heat it up enough that any greases would start to let go which wouldn't be very hot, would only take a second or two from an oxy
fonzo
vs berlina s2
tried it all
D3V14NT
Likes Shiny Things
Geelong, Vic
93 VP BT1 V6
I jammed a metal plate in between the flywheel and the starter motor opening. Then preceeded to place a breaker bar on the bolt with a bit of pipe on the end and belted it with a hammer. Cracked it after a few spirited hits.
Pub247
Melbourne S.E.
Ford Fairmont
Itry the above method if using engine and breaker bar dont work i usually let the breaker gain some momentum before it hits the chassis as you want that crack to happen
Heating the bolt aint ever going to work heat expands metal go buy some loctite freeze and release then retry the above method or engine cranking method garuntee itll work
