Removing Rear Bumper? how?
TheIceman
VY Ex-cop
i have a VZ ex-cop car sedan i want to fit a towbar, how do i remove the rear bumper? what are the tricks and where are the bolts?
TheIceman
VY Ex-cop
surely someone here has removed their VY or VZ rear bumper for some reason or another surely???
V
VZSV6
Guest
take it to a profesional. i have done it, but its hard to explain. you would need pics, but what i can tell you is start from the centre from underneath.
smyth
40
VY Executive
I swear I replied to this a couple of days ago but my post appears to have disappeared.
I'll type it up again for you later this arvo
TheIceman
VY Ex-cop
thanks, i will give it a try in a couple weeks wheni get my towbar.
omegaman
VZ Monaro
1 undo screws in wheelarchs and if mudflaps fitted remove!
2 undo 4 bolts inside boot under taillights, behind carpet side panels
3 undo plastic clips along top of bumper 6 of i think!
4 unscrew screws under bumper ( in centre underneath towbar cover )
Good luck
bigbastard
VZ SV6
I figured I should bump this up.
I had to remove the bumper bar so I can remove my tow bar pack. I followed this thread.
I took pictures as I went - except the screws under the bumper bar, but they are obvious.
These are the locations for the screws:
