See those 4 holes on the left and right edges of the unit? Get a wire coat hanger, clip 2 C shaped "bits" of wire, and jam them into those holes.
Then you can pull the unit out, and throw your new one in!
But you should also disconnect the - terminal of your battery if you plan to take anything or add anything to you system
