removing the tube shape rear muffler on standard v6 exhaust
muzza
51
gladstone
vx berlina
guys does any1 no how much of a job the rear tube shape muffler on a standard vs v6 exhuast system does ?i was toying with the idea of removing it ,is it just another muffler or does it do another function as well ? cheers muz
camstatic
I'm back babeh.
Regional SA
VZ SS
It'll give you a bit more of a note down low, but if your exhaust has the flexi pipe you'll get a loud whistle out the exhaust at higher rpm, people will mistake your car for a low flying 747. If you're going to delete the rear muffler, you'd better delete that as well. All that aside, removing the rear muffler should have zero negative effect on the workings of everything else.
ephect
Donating Member
VS Acclaim V6
it will sound louder as the muffers do exactly that, muffle the sound. wont be a problem as camstatic said on any negative effects. it just might sounds ****, might!
The main question is why are you toying with the idea of removing it? what are you trying to achive?
camstatic
I'm back babeh.
Regional SA
VZ SS
Don't forget the flexi whistle.:whistling
st3r3otyp3
Donating Member
VX HSV VX SS
The rear one is called a resinator, I`d thought I`d throw that in learning FTW.
