Does this help?
1. Remove Orange 1 & Orange 2, these two screws are visible at the top of the instrument panel before removing anything. Dropping the steering wheel to its lowest position before starting helps.
2. At this point you can remove the headligh selector if you wish, or else start removing the tabs holding the dash insert in. These are numbered Red 1 through Red 5. I personally like to remove the headlight/illumination switch and use that short side to start pulling the dash insert out.
3. Using a screwdriver insert it to where the Red X numbers are and lift gently. The tabs should just pop out. I may have missed a tab location on the far right side near the headlight selector - I can't remember... see if it gives.
4. After getting the insert loose, disconnect the Hazard light / Air Con / Demister plugs from the rear of the insert (and the headlight selector too if you haven't already done this).
5. Remove the now visable Orange 3 and Orange 4 screws. At this point the whole dash insert will just pull out. As you can see from the photo it is held in and made working by the Orange, Blue, Orange connecters.
All Done.
Murray
