nicko
Carbon Positive - DO IT!!
- Sep 29, 2007
- 1,435
- 35
- 0
- Location
- sa
- 75 cruiser ute
Tools and Parts:
-5/8" socket piece with a good socket wrench or breaker bar
-flathead screwdriver
-T30H bit (T30 hollow point torx bit)
Steps:
1. Disconnect battery
2. Remove airbag fuse
3. Disconnect airbag wiring harness from under dashboard (optional)
4. Remove the 4 torx screws from the back of the wheel to release the airbag and remove it slowly.
5. Keep the airbag facing away from you and slide you flathead screwdriver under the yellow airbag connector and pop it out.
6. Remove the airbag and place it in the open, out of sunlight, face up and away from static sources.
<!-- / message --><!-- sig -->__________________
Steps:
