baby_troupe
- Jul 30, 2012
- 13
- 0
- 0
- Age
- 53
- Location
- Ipswich
- VE Omega Dual Fuel
Tools needed
Flat pliers or similar to remove trim clips
Flat Screw driver
13mm ring spanner
10mm ring spanner
12 volt jump pack
Strap that will not conduct electricity to tie back positive lead
See images below to see example
1 - Open the boot
2 - Remove Cover to cubby hole
3 - Remove screw in clips to rear trim in boot
4 - Remove push in clips to rear trim
5 - Remove rear trim
6 - Remove both push in clips for side trim
7 - Fold side trimout of the way
8 - Attach Jump Pack to jump terminals under bonnet
9 - Undo clamps around battery tie back positive terminal so it will not short out and remove battery
10 - install new battery being carefulnot to let positive terminal touch the body of the vehicle as it will short.
Reverse above instructions to reassemble
Flat Screw driver
13mm ring spanner
10mm ring spanner
12 volt jump pack
1 - Open the boot
8a-Undo clamps around battery tie back positive terminal so it will not short out and remove bat.jpg60.5 KB · Views: 15,461
