Just to clarify, i actually haven't done the injectors yet. Compression is fine, fuel pump and pressure is all good, doesn't chew up any oil at all etc Engine is like brand new, has been babied its whole life. I'm taking it to a injector specialist on monday and he's gonna hook it up to a machine to diagnose if the injectors are at fault (which i'm fairly sure they are, seeing as i gained improvements after running a bottle of injector cleaner through the tank) 59L tank. I'm getting on average between 14.5L and 16.5L per 100 kms. Was mid 15's but recently had a bad tank last tank (after replacing fuel filter). Roughly getting between 340 to 380kms to a tank now. When i did start with it all though, i was only just managing to get 300kms. So shall get the injector check done on monday hopefully will be the cause of the problem, get them reconditioned and hopefully economy should be down to 12L to 13L per 100kms, getting 450kms to 500kms to a tank.
Will let you know how i go on monday,
Cheers,
Boojakz.
