Restick a "through" glass mobile antenna??
Jock
Hi All,
I want to re use a mobile phone antenna after having a windscreen replaced. You all know the type. Pull off the backing and whack both parts ob either side of the widscreen.
What type of glue would I use to restick it to the new windscreen?
Hope you can help
Jock
semi
GOD
WA
VR exec wagon
silicon maybe??
matrix
44
VT2 Acclaim
there is a glue made by locktite that is for sticking on rear view mirriors. i rekkon this stuff would do the job.
hakhawk
smooth moderator
Staff member
yeh, was gonna say, the mirror glue from loctite, but dont expect to get it off again, as that stuff can actually break the window if you try to take it off.
failing that, superglue, urethane.
whatever you choose, make sure the windows real clean, along with base of antenna.
Jock
I had another look and it when I scraped of what was left off the external antenna it seemed like a double sided tape of some kind. It was soft, about 2mm rhick and sticky. Anybody know where I would get something similar
Jock
hakhawk
smooth moderator
Staff member
supermarkets sell rolls of it and little 2cm square patches.
so do most auto shops(autobarn, supercheap) but supermarket is cheaper.
AirStrike
91' VN SS
Also Bunnings (need more sales so my shares go up:p)
Just get some mounting tape. Its what you use to hold mirrors up. Strongest double sided tape there is.
AirStrike :air:
Marks-VY
I love cars
56
VT2 Berlina
I once had to re-stick the rear view mirror to a car.
I found a "kit" for this purpose (auto shops should stock them) and it was brilliant. As someone else said, don't expect to get it off again. Other than that, I guess a good brand double-sided tape, which is what I think they use.
