Zerone_V
- Aug 30, 2011
- 838
- 25
- 0
- Age
- 48
- Location
- Sydney
- Lexus IS350 (SL)
The Factory Park assist should beep twice when the vehicle is placed in reverse.
If you have a factory Holden trailer harness, then the park assist will automatically switch off when a trailer is plugged in to the harness.
But otherwise, the unit should function normally.
The speaker is located near the rear parcel shelf, on the passenger side, and the Off,Low,High Switch should be facing the lugge area, and be easily accessed.
The speaker is very small, roughly 5cm x 5cm x 5cm.
It is possible that the speaker could be missing, removed, or damaged.
The main control module sits back from the battery, towards the parcel shelf and is roughly the size of a large packet of cigarettes.
It should have 6 small plugs coming out of it...
The good news is that if you were missing the speaker, or control module, then these can be easily and cheaply replaced.
The expensive part of the Parking assist system is the Sensors (and Painting them).....
I have a new Genuine Parking Assist kit here in front of me, and I will try and take some photos of the parts so as you can identify them.
