I stand corrected I could have sworn I used some in the channel of my VZ trims.
VE strip at the bottom.
VZ at the top.
VT-VZ clip top left. Has a VE clip sitting in the channel.
The VE VF channel tucks under a bit more.
The VE trims fit and clip into the VZ. They fit on my Crewman. Maybe not a sedan because the trim bends away a bit. I think the wagon would fit as it’s longer and straighter.
If you jammed something in there you could a VE clip to work in a VZ gutter trim.
I can’t get the VZ clip into the VE trim. It’s super close though.
VE VF in the middle. VT/VZ on the outer.
I guess we have to be creative now because these parts are not around much. Adapt and over come.
I have found a BMW clip that looks similar. Am going to try some. Also going to look for Opel and Vauxhall for the same clips. (I found the Crewman rear seat latch is an Opel part used in the Astra.)
These would be a good one for someone to 3D print in ABS.
