Scantool p0174 171
Hubuar
30
2010 VE International
Hey guys got codes coming up 171 174
Car running lean bit of a rough idle sometimes but runs smooth after I clear codes
Have cleaned maf, map sensor with contact cleaner seemed to help a bit but still getting codes
Also at idle it starts to lose power going up and down when left at idle for awhile with lights dimming and then getting brighter again
Have looked doesn't seem to be any air leaks and st fuel trim and lt fuel trim seems ok
Can anyone tell me if these ho2s values and ok or does ho2s bank 2 sensor 1 need to be replaced
Any help much appreciated
Holden VE international 2010
syked
Donating Member
2011 WM Caprice
Have you checked and cleaned the throttle body?
What about the PCV valve?
Have you also checked for vacuum leaks?
Skylarking
123
Downunder
Commodore Motorsport Edition
Not a GM engine but same principles apply...
Hubuar
30
Thanks for the reply I'll remove the air intake and the throttle body on the weekend check it and clean it also check the intake manifold gasket and let you guys know how it goes.
Hubuar
30
Also when ever I clear the code the car runs mint but after 5-10k the check engine light comes back on and starts running a bit rough
Skylarking
123
Downunder
You mean 5 to 20 kilometers and not 5000 to 10000 milomenters?
If so, the car has just gotten warn and may spring an intake air leak whicn casues the DTC...
So go for a drive to warm it up and once warn spray some water around the air intake. Listen for a change in engine note as you spray... If you get a change in engine note, you have a leak around teh area you just sprayed...
Takes a few minutes to do this and confirms an intake leak (or injector air leak, or...) before you take the intake manifold off...
Or just take off the inlet manifold and check everything (though i sometimes like the rule "if it aint broke, dont touch it" with modern cars).
Curious what the end fault will turn out to be :D
bazz61
gold coast
veII sports wagon 2011
A faulty battery can cause issues in engine management system especially on startup .
