tomsan
- Dec 8, 2012
- 89
- 12
- 8
- Location
- Melbourne
- Omega VE series 2 LPG sedan
Fixed recently parasitic drain fault.
Symptoms - This is hardware fault. It was all ok and nothing to do with computer , ECU etc
battery will go flat with in 15hrs of turn off. Needs a high capacity jumper to start. Jumping from other car may not work.
Alternator was charging OK.
Diagnosis
Disconnect battery +ve in boot.
Connect Jumper battery to Jump post in engine bay with 10amp meter between +ve jumper.
Make sure doors are locked with remote.
Wait for few minutes for system to shut down, meter needs to show <0.1amp
My car showed about 2.5amp. Removed engine bay fuses one by one. Removing AC clutch fuse fixed the reading. Also you can see AC clutch plate retracting with click sound. Put fuse back. Remove AC clutch relay fixed again.
AC clutch relay was jammed. It is 4 pin Denso sq bottom 13502753, GM generic replacement 92199313
Diagnosis
