chopsy
- Jun 2, 2006
- 232
- 1
- 0
- VN S2/ Original XRGT
I just done a L3 cluster conversion acouple of weeks ago have'nt really driven the car at all since then.What i what to know is my SPD light is coming on when i let the car idle and when i took it for a drive also my fuel is nearly empty so i'm thinking that it;s coming on instead of the fuel light.I thought the SPD light only comes on when you go over your set speed is'nt the cluster meant to beep when you go over your set speed and stuff ?.If so mine is not beeping does anyone know how i can fix this? one more thing i just wanted to double check that it's the yellow wire with a black line on it on the ecu that i run the wire from the cluster to?
