Cuzzy69
- Aug 6, 2017
- 52
- 10
- 8
- Age
- 48
- Location
- Vic
- Vs wagon exe v6 l67 vx
Vs auto v6. Dakota digital sgi-100bt $195 marks 4wd online
Take output from trans witch is a 2 wire. blue color do not cut just add wire !!!!other is brown. not needed
i wire ran under car up through a grommet under carpet into the dash area (insert into input!)
unit needs + and - anywhere fine
cut car loom blue purple wire to speedo and insert into OUT 5 of unit.
the unit displays from top to bottom of phone screen as its blue tooth
low
on
low/low
67 hz
i have a 3.89 diff and use a correction of 0.306 with 255/40/17 tires
low
on
low/low
67 hz
